Question for Frank
Frank's Tune
Hi BagMan,
We are having a problem sucking the tune out of Franks bike with TuneEcu. Tried on Sunday and received an error message which prevented reading the map
We will keep you updated.
Bruce (also known as R3Tripper)
Hi BagMan,
Bruce,
Thanks for the info. If you can't pull it with tuneecu, does tuneboy allow you to export the tables? I can hand jam it as long as I have the data.
Thank,
BaGMaN
Bruce, what does the D stand for.lol
Thanks for taking over here. BTW, the tune looks great from top to bottom with your AFR Gage. Going to install the PCV with the Autotune and a 0% map. Just want to see what it shows.
later and tell the wife I said hello.
Frank & Bruce,
Any luck pulling the tables for the tune. Map or just the tables so I can hand jam it in?
Thanks,
BaGMaN
any luck or update on this. really could use some help. have a 200 mile ride to get to the dyno shop and really would like to be close before i head out.
thanks,
bagman
Hi Bagma,
I can give you Frank's tue in TuneBoy format. We cannot get TuneEcu to work on Frank's bike
Also I have relocated from Houston to New Berlin WI so do not have access to Frank's bike to resolve the TuneEcu problem. Let me know how you would like to proceed?
Bruce
ok, took the 3 K&N & Tors tune from the TuneECU site and added 5% to the L tables & added 5% to the F-Trim table (since the F tables are acting up if you try and change all the cells at once). Will load this on the bike tonight and taking it to the dyno on Friday. Hopefully this will hold me over to get it to the dyno.
Bagman, if that looks ok on the dyno would you mind sending me the tune with the changes you made to it? My jardines are scheduled to be here Friday.
once it's dyno'd and the map is right, i plan on posting the results w/ the map. plus send the map to the tuneecu site so everyone has access to it.
Write your reply...
