Question about Noise while releasing clutch
when you get chance, can you ask them which part # they will change from below:
I will most definitely get any info I can from the tech and share.
So far the dealer has confirmed that there is something weird going on and they are opening a warranty case with Triumph.
its weird that
- there is no pattern for that sound/noise
- doesnt happen always from a cold start
- doesnt happen in all gears
- doesnt happen when the bike has run enough 10-30miles/ or when its hot.
and it feels like some gears trying to connect when you move bike from stationary to motion in gear 1 at very low speed
not sure if its clutch or gear box or shaft, three variables working here.
I am going to jump in here because i know a lot about clutches.
when you slip clutches and the oil does not have the correct additives then the clutches will chatter/judder/squawk in other words they are not making a smooth transition when appling.
if i had a newer rocket i would get info on what type oil everyone is using especially when making noise.
15w50 is what I am using for last 1 year.( 3rd oil change)
I was thinking about the brand type rather than the weight.
I am thinking that different brands of should have different friction modifiers.
I am not claiming that I know more than Triumph just putting out one idea.
so first one was whatever triumph put in at factory
second was mobil
3rd was Motul,
I am waiting on triumph own brand oil for this upcoming oil change.
