Tonester
#justsayin'
Hi guys, as the heading reads... 'Project 'Hydra'. I renamed my footboard conversion on my 2014 Roadster to Hydra because as soon as I solve one problem I seem to create another two. When I'm finished I'll do a proper step by step info sheet with some of the things I've had issues with. Anyway, the latest thing the challenge my sanity is the fitment of the 'car type' rear brake pedal on the Standard rails that came with my Footboard kit. Note: This is not the rear brake pedal that came with the kit- I prefer the look of the bigger brake pedal.
I didn't think that it would be an issue as I've seen the bigger brake pedals on other rockets... Here we go...
Issue 1. The pedal binds on the 'rail mounting section' (shown in yellow). There's very little movement before it locks up. Has anyone had any issues with this? Can anyone tell me the distance from the edge of the pivot bolt to the edge of the arm (shown in red)
Issue 2. After I bolted the pedal on and left scratching my head about it binding etc. I noticed that the foot section of the pedal didn't look right. It looks to me that it is bent up and inwards... Is it just me? Ergonomics? I think the second picture (without the yellow lines- looking rearwards) shows it better. I just want to check with you guys whether I need to send it back for a replacement before I let loose with a blow torch, a big hammer and an angle grinder!!! Any advice/help would be very much appreciated. Thanks!
Tony
Tony
