1K9
No'mo Rocket 4 me
Just a theory. For those with the dreaded sudden 2000 rpm idle or erratic idle problem. After confirming that my malady would be fixed by disconnecting the idle stepper motor, today, I got to take the linkage off. Cut the cotter pin took the two little washers off. Taking the linkage off was difficult and revealed a very gummy linkage mechanism. The only way to lube this is to disassemble, clean well and dry lube the carrying shaft on the throttle body. I think the efforts to lube this area with stuff made the problem even worse by attracting dirt. To get it out one must remove the idle motor nut also. To the sudden idle surge sufferers, one more thing to try. Perhaps the motor has a voltage to check and make sure it is the motor before you trash or change it.
