Pic of Triple K&N's Under Bearclaw
Personally Ishmael, I wouldn't have the edging but you could easily try it to see if you like it. It gives it a different look and could look pretty good with your cut on a black bike.
I agree
As for a template, don't see how that would be any easier as it would involved measuring and guessing just to line it up. I cut mine more or less like Mitch's too. I measured under the claw from the top of each filter to the bottom of the claw - they're different. Then took the claw off, turned it over and marked the inside, starting with the centre of each pod and then drew a line more or less following the line of the bottom edge. I initially drew my line about an inch below the top of each filter. I marked and cut from the inside because it's very easy to slip with the cutter and leave marks on the chrome. I started taking less than I wanted but it's easier to take off a bit more than to put it back on! Took me three goes and I've and finished up with it about 1/4 inch above each filter! The back filter is still touch the cut edge so I need to take a little more off there.
Attempting to make a template might not be easy and for someone to use the template might not be easy job as well.
I cut mine from the front side but double coated the entire front side of the claw with 2" (blue) masking tape just in case of a slip of the Dremel tool. Marked where I wanted to cut with a black Sharpie , cut, then removed the tape once I was done.
I put a bead of silicone in my trim keeps all moisture out . To copy my shape all you need do is trace the bottom edge of the middle bubble onto cardboard cut it out and use it to trace an outline on all three exactly 6.5 cm up from the bottom of each and just join them up freehand . I think the trim is a good idea because even the best cuts have minor imperfections I haven't seen one yet that you can't tell it was cut by hand . Just my opinion ofcourse
Sent from my iPhone using Tapatalk
Interesting discussion about technique and aesthetics this.
Thanks for your views fellas.
anyone happen to know what a new claw is worth, just outta interest?
When I saw the one on fleabay I looked into seeing what a new one would cost and it was $125 US. Hope the link works:
2010 Triumph ROCKET III Parts, 2010 Triumph ROCKET III OEM Parts - BikeBandit.com
I think Hanso found one for about $90 from NCY.
Yup actually $92 (+ postage couldn't tell how much there were a few other things in parcel) after us exchange conversion, Call Jason in Spares tell him" Hans:cool: from Oz(just:rolleyes: kiddin) sent ya" he'll look after ya, he is a good bloke:), I have spent about 3 grand there but it would have cost me 3 times as much from Aussie dealers :eek:
Just wanted to through in my take on the filters. I also removed the secondaries when i did this mod.
Where did you get that coolant overflow bottle, and what part no for the cables to connect to it?? Any chance anyone has pics of a set-up like this showing how it is installed/routed?
