I finally got around to install the new bars (Khrome Werks 300211) and the Avon grips. A bit of a pain as the brake fluid reservoir didn't want to sit nicely on the bars. But it's all on now and I just got back from a short test ride in the neighborhood. I have the risers on as well and the cables are pretty tight... All in all.. no issues with the clutch, the brake line is the tightest one but still has a bit of a slack.
What a difference!!!! My wrists are now at a more natural angle, arms are just below shoulders and it all feels so natural!!!
Thanks @Earthquake for the suggestion!
I didn’t realize you had aftermarket riser if you fallow the front brake line down on the right side of your sitting on it there a mount to the triple tree clamp if you run a longer bolt and spacer it’ll loosen that brake line right up
Those risers are actually for Thunderbird but they fit perfectly with the stock bolts.
I'll look in my bits and bobs cans for something to loosen that triple tree clamp up a bit. Thanks!
Actually my bad that triple mount was on my classic on the touring I don’t think it’s the same mount if you decide to get longer brake lines adept motor sports with extend a stock length for you
Tourings have the worst handlebar position I've ever seen, angles your wrists terribly. First mod I made on mine was Classic bars and Rivco risers. Bars were gifted by a site member, unfortunately Rivco no longer makes the risers, but for me it's the perfect setup.
Are these the Rivco risers you have? I bought them from Jay a couple months ago, with the intention of pairing them with Classic bars. But before I pull the trigger on it, I want to talk to somebody that runs this setup on a Touring. I know for sure the wrist angle will be much better than the stock Touring bars... maybe perfect. I sat on Sparky59's Roadster... and it was nice. But that bike has a considerably shorter distance from seat to triple tree than the Touring. So the one thing that I want to be sure about is...how does this affect reach? I'm about 6ft tall with average arm length for that height. I don't want to find myself with a reach that is putting my back and shoulders in a bad position, and feeling the pain.
