RazMan
Rocket Addict
Sounds like a plan! - I was thinking that dropping the voltage was the answer but maybe had it all wrongRather than Series, use a PARALLEL resistor between the high beam and ground - I'm guessing at value, but try 1K 1/4W; if that does not work try progressively smaller resistors - 470 ohms next still good at 1/4W; if you need to go smaller still, then you will need to increase the wattage accordingly.
