Mittzy
The Hooligan - Just Doing Stuff
- Joined
- Aug 29, 2011
- Messages
- 8,533
- Location
- Brisbane, Australia
- Ride
- 2020 TFC #385, 2014 R3 Roadster 230hp (BRUTUS)
I got some replacement boss mounts and welded a tiny piece of sheet metal to one end then welded in place of the one that i cut off.How did you weld up the holes in the thread bosses? Only way I could see would be to cut off the bosses, weld up the holes and then replace the bosses? I would like to keep the heat shield such as it is. It does help a bit
I do have a tig welder but as it was 20 years since i last used one - I was a bit rusty.
Last pic was when i cut the second lot off and patched the pipe properly and put the thicker flange plates on - i was also messing arround with making a heat shield - still on the project list.....
