Mike Rocket
Rocket 3
I would just clean the non return valve its just a snap ring to take it apart. Yellow arrow, green arrow points to the area you can see to check the oil spray jets.
when I get to my computer I'll post a sump picture showing the bolts and the one usually missed.![]()
Thanks again. Fantastic. Just one thing, if the sump plate is off and I top up the oil tank will the oil just run straight through as the oil drain plug is fitted in the sump plate and it will be removed. (or am I being dumb asking this?)
