Starmanut
Nitrous
- Joined
- Jun 12, 2017
- Messages
- 1,205
- Location
- Spanish Fork, UT
- Ride
- 2010 Rocket III Touring, Suzuki Boulevard M50
First.... You all are absolute geniuses, it was the battery. Second... THANK YOU! I was just about to pull the trigger and buy a new ignition switch. This was a case of "Chicken Little and the sky is falling". I replaced the spark plugs and was absolutely convinced I caused the issue somehow, I hate coincidences.
The battery (with no load) had a float voltage of 12.3v, I was sure it wasn't the battery, never stopped to measure the voltage when all the harnesses were plugged back in.
Where can I find more information about this EB bypass?
The EB bypass was one of the first things I did. Mine stopped working about 3 weeks after I got it, too. (ended up being a short right off the positive battery cable).
I got it fixed with the help from this forum. (LOTS of help!!!)
I found a burned connector wire that the previous owner had patched up during my search for the problem, so the EB route sounded like a good way to go.
Here's where:
H4 Kits
I got the "H4 Single ‘In Shell’ Kit" the relays fit quite well inside the headlight shell on the Touring. And I even had room to swap out the old H4 bulb with an LED replacement. (I don't drive at night, so I wasn't worried about getting a whole new lens setup). The LED draws even less power.
Later I installed a fuse block, but the bypass worked very well directly connected to the battery.
Glad you got her going!
And, oh, yeah, that Decosse Keyless would be a great way to go, too!
