About a week ago, it started to backfire and not run smooth at low RPM's. When the throttle is twisted, it runs GREAT. I replaced the plugs, and washed the air cleaners, without change. Then I replaced the high dollar fuel filter (in the gas tank), put it back together, ran it for a couple minutes and went to bed. Started up in the morning, then with a big backfire, it stopped running and wouldn't restart. I called the local service dept. to see if there was a special bleeding sequence as I know it got air in it changing the filter, but he said turn it over, and it should bleed out. It hasn't, and ended up putting the battery charger on it. Has anyone had a similar experience? Driving my truck sucks! Thanx Stick
