jake shaw
Turbocharged
Prince Edward Island, Canada
2014 Rocket Touring
As the title says my low beam has stopped working. It is a LED unit which tests fine on the bench. I have had the switch cluster apart and sprayed with electrical cleaner', checked all the fuses I can find, tried the old sealed beam, (does not work on low beam) Any thoughts where to look? All other lights work properly.
Put a test light or volt meter on bulb terminals, move light switch from low to high to see if supplying power to both terminals. Possibly someone installed relays for high and low beams, or a switch problem.
Thanks Gerald. A low beam relay (Eastern Beaver kit) solved the problem.
Write your reply...
