North American Indian trick 117 Log Book
Micksan
Del City Ok
Now that the weather is slowing down if not stopping the riding many of you will be wanting to catch up on the maintenance. You might be well advised to start a folder on your computer to keep track of what and when you did something , plus what you used.I guess after 22 years in the Navy I log in everything
I have four bikes to keep up with so it makes it a lot easier to figure out when I need to change oil , fork oil ect .
It may sound like a pain but has a lot of advantages .How many miles did I get on that tire?? Another plus is a big advantage when your trying to sell your bike . Gives you a big advantage when you can show the potential buyer that you really did take care of your bike . Here is a sample of what I do .
_________________________________________________________________
2006 Rocket 3
Purchased 10 Nov 2010 >>>>30,215
Tires >>Front 150/80/17 **** TP34
Rear 240/50/16******TP 42
Engine oil 10/40 >>>5.7 Qt …Change every 10K
Final drive 75/140>>>.7 lt (5.7 oz)
Fork Oil >>>SAE 0 W *****667 CM +- 4cm
Fuel Filter Wix 33032 >>>O’Reileys
Oil Filter….. Napa>>>PS1358
Spark Plugs >>>NGK DPR8EA9 (6ea) ***Gap .9 mm
Valves In >>>.10>.15 mm
Out>>.15 > .20 mm
2010
Install TPS>> 6/29 >>> 22,739 Previous owner
Front Tire>>>Dunlop D404 >>>7/21>>>24,576 Previous Owner
Brake pads 30 K
Oil F&R >> Amsoil >>11/23>>>>>>30300
Rear Tire Bridgestone >>11/23>>>>30300
K&N Air Filter >>>>>>>>>11/22>>>30300
Spark Plugs NGK >>>>>12/12/10 >>>>30460
Lighting Relay system >> Eastern Beaver >>>12/12>>30460
Fuel Filter Replaced >>>>12/13>>>>>30,460
Cleaned inside tank , Adjust Fuel Float >>12/13 >>30,460
I do the same thing. I can't tell you how many times I refer to information there to see when & what was done. All my items are logged there, from the chain saws, lawn tractor, camper, bikes, cars, tiller, etc.
Too many things to keep track of for such a "Pee Brain". Good thought to share with everyone Micksan.
See ya.
I help a lot of local riders with their bikes. You would be surprised how many people do not know when their oil is due to be changed , or on the older BMWs when to pull the tranny to grease the spline gear. Ect
