Ian is right but I do not believe you pulled the secondary TPS and I do not believe you need to at this time.
That is correct, I did not pull the secondary TPS... I cleared the error code, took it for a short blast and all seems well for now, I'll find out in the next few days... A BIG THANKS TO EVERYONE FOR THE HELP!
good to hear hope it keeps on plugging away for you. and just so people know you can change the idle rpm by using the voltage tolerance to raise or lower the idle. Keep that link I sent you on the ISCV reset and stepper motor replacement and setting it might be a little confusing but if so do not be afraid to ask there are plenty of people here the are willing to help.
@warp9.9
Thanxs for sharing that PDF regarding the TPS, stepper and ISCV adjustments.
I shall read through it after my recovery from this thread and when next I have need to shake my head until it hurts like the Aflac Duck talking to Yogi!!!
:eek: o_O :unsure: :confused: :rolleyes: :banghead:
Seriously though, thanx, Amigo!
Write your reply...
