ok here is the
TPS # T 1245113
And Andy Lauitzen's at North County Yamaha is the best with Triumph parts prices shipping (anywhere) email address is
andy@ncyyamaha.com
He is a good dude and is very helpful.
Now I can see where it might be the TPS playing up or the idle stepper motor is not set up right and you should do a full ISCV reset to see if you can get any changes. I always carry a TPS with me on trips just in case but if yours is not idling I keep asking myself why and besides the TPS I keep wondering if the gap between the idle speed control cam and the throttle roller are set right. If you pulled the stepper motor and then just bolted it back on I bet it is not correct. if it is go by a Mega Ball ticket because you have a good chance at winning.
Idling problems can be picky to work out when you start understanding how many variables can creep in and mess with you. This is because of tolerances in setting the sensors and stepper motor gaps. Not to mention there is only one throttle body that is rigidly attached tot he Primary TPS which is #3 all the throttle bodies have individual throttle plate shafts and they are tied together by the two adjuster screws. If you think about it if your balancing throttle bodies and you only have to adjust #3 then you are moving the TPS sensor when you adjust the screw. So the TPS volts moved and are not in sync with the original setting done at #1 Throttle body. Of course this can be negligible and stay in tolerance or not depending on the movement.
My point is it sometimes take a little while moving back and fourth until you get the optimum function.
As stated above about cleaning and lubricating all the springs and linkages can and will make things work more consistent. If I know I am going to mess with the TPS primary or secondary, or the Stepper Motor and perform a ISCV reset I always clean and lube the linkages first.
