Ok, I've searched previous threads but haven't come to any conclusions to my issue... I have had the common high idle issue for a while but it has been very intermittent but now my '05 will not idle, when I let of throttle it just totally shuts off like the the fuel is completely shut off. Could my primary TPS issue be causing this. I pulled the stepper motor off and let it hang free as I started it and that made no difference, still no idle. My TPS voltage shows .64 volts at 0% throttle but wouldn't that cause higher idle instead of no idle, I've cleaned the crank sensor also..... Any help with this issue is greatly appreciated, I want to ride dangit!
