How about
Looks interesting minus the backrest. Who is the manufacturer?
Fork rings that are 58mm diameter to mount after market turn signals and lose the giant silver bug magnets.
Dual 5 3/4 to Single 7" headlight conversion kit...
GSG in Germany
Ø 49 / 50 / 55 / 56 / 58 mm
Ø 35 / 36 / 37 / 38 / 39 / 40 / 41 / 43 / 45 / 46 / 48 / 50 / 51 / 52 / 53 / 54 / 55 / 56 / 60 mm
Stock looking barend weights in black or chrome with integrated led turn signals. Copied this of Claviger, but yes I would go for it without hesitation as long as they are easy to wire up..
Wonder if these would work. FUGLY but under US$10 with free post in Oz may make a concept test possible.
See photo #1 with a 58mm gapped ring that it would be possible to use bent/curved bolts to get it to clamp beyond nominal 54mm max intended.
PAIR Bullbar Mounting Bracket Clamp FOR LIGHT BAR Rigid HID ARB MOUNT 49 54mm
These clamps will tighten down from 49-54mm.
  • Works with nearly any light bar with mounting bolts coming from each end.
  • Best no-hole drilling solution for mounting Light Bars
Suitable stud size: 14mm (light bar bolt)
Weight: 350g (Per Pair with package)
  • For(49-54mm) Diameter BullBar
  • Stainless Steel Allen Head Bolts
The <$10 clamps arrived today and very surprised and delighted to find made 100% from quality aluminum rather than plastic. The 58mm inner diameter is usable as the holes still align in a straight line so the bolts will not have to be bent/curved to fix.
I think I will find a use for them sometime.
