Sorry to hear about the troubles you have had. Thanks for sharing. This is good to know. I am heavily considering a Mustang for the backrest, but will keep this in mind. I may just have to ride up there first and offer my bike as a calibeation unit for their jig before deciding on them or another option.
No problem, I think it’s important to share this stuff for the benefit of the masses.
The seat itself seems comfy but I haven’t ridden anywhere on it yet.
This is my first mustang seat, I have had several Corbins for other bikes... I went with Mustang this time as they seem to have such good reviews online and none of this stuff is available to inspect at a local supplier/shop..... to my eyes, the Corbin is better quality materials and more attention to fit and finish from what I know of them..... they are ‘harder’ but they are still very comfortable .... fairly sure they have a backrest option too
Of note, one of the factory drilled holes for one bracket had been re-drilled and there were two holes overlapping under the bracket that seat pan should have been discarded if not correct but perhaps Mustang thinks what the customer doesn’t know doesn’t matter ... a couple of the rivets holding the seat covering were a bit loose also so I replaced them... quality control is obviously lacking or they have some incompetent or disgruntled workers at Mustang - the lack of response when an issue is raised just tells me they don’t care.
as others have said you probably could just use the rear fender bolt... but I personally don’t trust tension only to hold the two pieces under stress when it’s a seat that comes apart in two pieces.... I also believe in things working the way they are supposed to
Some of this is design stuff... and if designed to be able to be used as a rider only or a two up seat then it should work as such, without the rear seat there would be nothing to hold the rider seat in place if the side bolts weren’t used.
I have made this work but I likely would have just returned it had they given me the approval to do so .... I suppose I could have just sent it back but who knows what would have happened without an RMA... it’s also expensive to ship overseas...
Buyer Beware!
