Speed Sensor Pulse Rate Calibration
• Turn the ignition switch OFF. Press and HOLD the RES and ON-OFF buttons, turn the ignition switch ON,
HOLD THE BUTTONS UNTIL THE SWITCH INDICATOR LIGHT COMES ON GREEN (a few
seconds), then release the buttons. The cruise control is now in speed pulse rate calibration mode.
• Ride the bike at 70 kph (45 mph) and hold the speed STEADY. The GREEN indicator light will be flashing as you ride the bike. The flash rate will vary with the bike’s speed and the frequency of the pulses coming from the speed sensor, so the flash rate may be very slow or very fast or anywhere in between, in some cases it may be so fast you cannot see the flashing except at low speeds.
• Press and release the SET button once. The indicator on the switch will change to RED for two seconds and may flash yellow during this time. The computer will record the pulse rate of the speed signal. Hold the speed STEADY at 70 kph (45mph) for two seconds until the red light goes out. The light will resume flashing green from the speed signal after the red goes out.
• If you are not sure that your speed was correct or stable, adjust you speed to 70 kph (45 mph) again and simply press SET again. Each time SET is pressed the speed pulse rate will be recorded and saved overwriting the previous setting.
• Stop the bike and turn the ignition switch OFF, DO NOT TURN THE IGNITION OFF BEFORE THE BIKE HAS STOPPED MOVING.
This completes the speed signal pulse rate calibration.
