Making the 3R R'er
M10 x 1.25 x 100mm x 2. Au$5
20 minutes on the lathe and I have a bar riser kit.
21mm rise should give me clearance enough to roll bars back to a flat orientation.
Rocket 3 handlebars have rubber mounts in top yoke, which are compressed by a dished washer below and shaped riser above, much like a cars shock mount rubbers.
I had to emulate the shape of the bottom of the riser with my spacers, to provide the necessary compression of the rubbers.
The brass rings sit atop the spacer and fill the bottom of the risers.
