Low idle
rainman
Seabee can do
niota tn
06 classic 2012 victory xr
Me and Wendy went out for a ride today and bout halfway through it my 06 classic started to have low idle when stopped at the red light and died on me at one of the stops
I get fuel at the same station which is 3 miles from the house and never have had a problem there usually get gas in one vehicle or another bout every other day
Still could be injector related or plugs losing spark power.
Got TuneECU?
Check your vacuum value, throttle balance and TPS & ISCV
If not I'd order the cable, and check vacuum tubes right now
Yes u have tuneecu it will be the weekend before i can do that
I remember being so disappointed, when I first took delivery of my bike, and it exhibited that behavior. I complained, and supposedly, the dealer updated the ECU map.
The next time - well documented here - after checking many things, replacing the idle stepper motor did it.
Will be following this with interest. Hope you get it sorted soon. Thank you @R-III-R Turbo for timely assist.
Went riding today and still have low idle issue but it runs like a scolded dog no hesitation at all but it is running a little rich cause u can smell it
I have adjusted the throttle body so they r in sync
And according to tuneecu the tps is where it is supposed to be
The stepper motor is supposed to be fine also
And also sprayed wd40 on the stepper motor as suggested by Scott
