Status
Not open for further replies.
From what I was told, I have Nevs slotted street cams, hi comp pistons and as far as the tune, I wouldn't have a clue. I gave my bike to Dave who was recommended by Mr Lush who done all that with the gearbox update kit after having the second gear issue.
This is part of this invoice for repairs. I also had some repairs on here for the crank case after my accident. This excluded labour.
Parts to date for Triumph bike
Parts Heavy duty clutch kit ($425.00), cams x 2 ($1225.00), pistons x 3 ($850.00), slotted cam gears ($165.00), update kit ($322.22), cylinder head gasket ($124.09), con rod bolt x 6 ($90.54), con rod bearing x 6 ($87.24), water pump seal ($6.70), oil filter ($23.00), freight ($55.00), crank case repair ($324.50)
3,362.08 + Gst
Adrian, There will be more parts to come
including shims, oil, coolant, battery, etc.
daaaammmmmnnn, It's not feasible to ship my bike to australia but I have the update kit and my bike needs it so wouldn't it make sense to do the update at the same time to save a little labor or is it too much of a cluster f**k to find someone willing And able? thats a really good looking street power curve.
That's what I done all at the same time. While it's apart might as well do that bit extra.
i'll have to find someone here qualified to do the work, Did the update fix your tranny? my symptoms are grinding going into 2nd and popping out of 1st and 2nd if it's not slammed. otherwise its pretty smooth.
Or something like this.
WE can give you that with just cams no pistons or porting
Status
