cr0ft
My 8700 Evo 2 comes with the same connector any halogen light has, so you literally just replace the reflector with clips, don't require any tools beyond a screwdriver, and then plug in the cable into the existing connector and you're done. Basically as easy as replacing the headlight bulb in the original.
I believe the 8630 Evo model has a different connector though, for some reason. If so you either need to replace the connector on the bike cable - or (what I'd probably do) cut off both connectors and splice the three cables together using Posilocks. And then probably shrinktube over the posilock, but that's optional.
