Thanks, I will check in the morning. It's got to be something silly on a new bike.
Just returned from a ride and discovered the upper left side of my engine is ALSO weeping coolant! Seems to be somewhere behind the oil tank and slightly in front of the throttle bodies cover and continues to be wet/moist to the rear of the engine. I did notice a slight smell of antifreeze while riding. I had the annual service performed a couple of weeks ago, hopefully the mechanic did not secure the reservoir cap, although the coolant level is right at the MIN line (if serviced, I would think the level should be at MAX). If not coolant cap, possible head gasket leakage?
Mine was leaking coolant from the hose in front of the oil tank and I only needed to tighten the clamp to fix it.
Yep mine was also ( the little bypass hose) the funny thing was Baxter's put red coolant in her so she looked like she was bleeding all over the garage floor :D
When she had miles on her and long in the tooth the overflow hose started leaking but I would only get wet when I road her hard enough to really heat up the water :)
