Keyless Ignition
I hadn't seen it, but it looks like it should do the job. However, it is a bit more expensive than what I did, but it is less expensive than some other RFID systems that are around.
Just found these in Bulgaria. http://shop.teracom-bg.com/product/76/locky-bp.html. Must admit I'm tempted to get 2 or 3 and some keyfobs. I've loads of relays lying about. Be **** fine to have one fob that would switch all 3 bikes.
Me Likey !!!:p
The problem is they're in BULGARIA. I've had some recent issues with Bulgarians promising the undeliverable - so I'm a bit wary. But I'll SKYPE them from work a bit later on. Postage is **** cheap - but fecking slow though. Pay extra and get EMS - ALWAYS.
Well I had a good long chat with them this morning (well, I was at work - and bored stiff) - They were interested and forthcoming about shipping issues.
So then. How many bike wiring looms do I want to wreck? 1, 2, 3? decisions decisions ............
Ideally of course the best thing would be a system that switched on when you drew near and off when you walked away - mmmmmmmmmm
3 meters activation distance would be perfect.
Why wreck them, it should be possible to splice the cables, isn't it?
From what I have seen on their site, the product needed would be the BF Lock, exactly this one is not on their online shop.
Apart from that, how safe are those to being scanned/read by thieves?
Being RFID they should be near impossible to read - these are proximity keys - about 3-5cm.
Long range systems start to get a little more expensive - http://rss-systems.de/ .
The teracom site is not all that easy to navigate - it transpires that there's basically one model - Locky-B which is configurable to BP,BF.BT modes. Software is on their site - but only the Bulgarian part. It's now on my laptop.
Splicing :eek3:<shudder> - this requires a barbagris sub-loom solution :cool: . Everything has to be reversible.
Can you source OEM connectors?
It's just a case of trawling the web to find some that fit. I found compatible headlight harness connectors easy enough (OK they're white not black). I've not looked at the Triumph switch connectors yet.
What does the OEM connector look like? - Nice close up hi-res pictures pls.
The motogadget is MUCH tidier - it's smaller and sealed.
New Style Ignition switch connector
Sumitomo DL Sealed Series 8 Position
M(6195-0054)
F(6195-0051)
Still trying to find a source to purchase them from. :(
