INJECTOR INFO AND PROBLEMS
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
Poblem
When bike sets injectors leak and floods motor hard starting and when it does start it is missing and takes a while to run smoothly. Will run good till i let it set for over an hour then same problem
QUESTIONS
1ST WILL cleaning fix a leaking injector?
2nd. What is triumph number and
Is there an after market parts number
3rd what would you do?
And thanks for any replys
Herman
Ill send you a set. Ive got your address there at the shop. How fast you need them?
These guys are im cali, they put out nice pieces, bosch, 370cc 375cc they can hook you up, good prices. Five-0 is pretty popular like that outfit in Australia i draw a blank. Just dont get too big or its gonna struggle. 370cc is stock
May I suggest the simple and local solution. Remove your 3 injectors and take them to a local fuel injection shop. Have them cleaned and inspected. They can determine if the injector is actually bad or if you just need new O rings.
Had mine done by a local shop and all is good. Cost $16 each for the service and new o rings.
Thats awesome, what were your cc numbers on the 3?
