Ignition key relocation
Great job. Removing the upper triple tree seems a bit dramatic. I used a thin screwdriver to tap a slot into the soft breakaway bolts and simply screwed them out of the ignition switch. I also have a power port in the old key location. I used the top of a food can as a backer to the chrome cover.
I tried to get those bolts out without removing anything. Even after I took the top of the three off they would not budge so I drilled the buggers out. I am pretty good at this stuff as I have a metal working trade background. I reckon it was easier taking the top tree off. Good opportunity to polish those hard to get at paces - no that I did tho.
ok got it, for some reason the pix did not show up on my phone... Let me find out what is up with the 2nd backrest I ordered and we can work something out, if you still looking for one.
Thanks Tony, all fitted up with the new Sumitomo connectors.....even mangaed to get the bolts out without having to take the triple tree top off.
Good one mate. I think my bolts were too tight. I couldn't even get them out by tapping them even after the tree top was removed.
had to drill them out.
Mittzzy,
Only been like 8 months since I bought the harness, but I pulled my triples today to for powdercoating. Figured it on my makes sense to do it now while all the silver bits are being coated.
How did you mount the ignition barrel in the new location down there? Custom fab a metal bracket? If so, do you happen to have a pic anywhere?
Used the bracket that was behind the left hand cover - just cut the excess stuff off.
You are the man. Didn't know there is a bracket back there already lol. So excited to finally have everything I wanted done aside from the carp/nev engine work, next year that will come.
Hey Mittzy. Just wondering if you still have any of these relocation harnesses keen on doing this mod. How much?
