martym52
2014 Indian NOT a Four.
I didn't get the picture but here are the specs.
INDIAN® CHIEF® VINTAGE
SPECIFICATIONS
ENGINE
ENGINE TYPE THUNDER STROKE™ 111
DISPLACEMENT 111 CU IN
BORE X STROKE 3.976" X 4.449" (101MM X 113MM)
COMPRESSION RATIO 9.5 : 1
ELECTRONIC FUEL INJECTION SYSTEM CLOSED LOOP FUEL INJECTION / 54MM BORE
PERFORMANCE
PEAK TORQUE RPM 3000 RPM
PEAK TORQUE (J1349 FT-LBS) 119.2 FT-LBS/ 161.6 N M
DRIVECHAIN
PRIMARY DRIVE GEAR DRIVE WET CLUTCH
CLUTCH WET, MULTI-PLATE
GEAR RATIO (OVERALL)
1ST 9.403 : 1
2ND 6.411 : 1
3RD 4.763 : 1
4TH 3.796 : 1
5TH 3.243 : 1
6TH 2.789 : 1
FINAL DRIVE 2.2 : 1
CHASSIS
SUSPENSION: FRONT - TYPE/TRAVEL TELESCOPIC FORK/4.7 IN (119 MM)
SUSPENSION: REAR - TYPE/TRAVEL SINGLE SHOCK / 3.7 IN
BRAKES/FRONT DUAL / FLOATING ROTOR / 4 PISTON CALIPER
BRAKES/REAR SINGLE / FLOATING ROTOR / 2 PISTON CALIPER
TIRES/FRONT DUNLOP® AMERICAN ELITE 130/90B16 67H
TIRES/REAR DUNLOP® AMERICAN ELITE 180/65B16 81H
WHEELS 60 SPOKE 16" X 3.5" FRONT AND 16" X 5" REAR
EXHAUST SYSTEM SPLIT DUAL EXHAUST W/ CROSS-OVER
DIMENSIONS
LENGTH 103.7 IN
GROUND CLEARANCE 5.5 IN
WIDTH (US) 40.4 IN
WIDTH (INTL) 39.8 IN
HEIGHT 58.7 IN
SEAT HEIGHT 26.0 IN
WHEELBASE 68.1 IN
RAKE 29°
TRAIL 6.1 IN
FUEL CAPACITY 5.5 GALLONS
WEIGHT (EMPTY TANK / FULL OF FUEL) 801 LBS / 835 LBS
GVWR 1260 LBS
COLORS
AVAILABLE COLORS THUNDER BLACK, INDIAN MOTORCYCLE® RED, SPRINGFIELD BLUE
STANDARD
STANDARD EQUIPMENT ABS; CAST ALUMINUM FRAME WITH INTEGRATED AIR-BOX; CRUISE CONTROL; HIGHWAY BAR; INDIAN® SCRIPT TANK BADGE; KEYLESS START; LIGHT BAR; PREMIUM LEATHER SEATS; QUICK RELEASE LEXAN WINDSHIELD; QUICK RELEASE VINTAGE LEATHER SADDLE BAGS; VINTAGE FENDER BADGE
ELECTRIC
ELECTRIC TANK MOUNTED ELECTRONIC SPEEDOMETER WITH ODOMETER; DUAL TRIPMETERS; DIGITAL TACHOMETER; AMBIENT AIR TEMPERATURE; FUEL RANGE; AVERAGE FUEL ECONOMY; BATTERY VOLTAGE; GEAR POSITION DISPLAY; REAL-TIME CLOCK; VEHICLE TROUBLE CODE READOUT; HEATED GRIP LEVEL (IF HEATED GRIPS INSTALLED); LOW ENGINE OIL PRESSURE; AND 9 LED TELLTALE INDICATORS: CRUISE CONTROL ENABLED, CRUISE CONTROL SET, NEUTRAL, HIGH BEAM, TURN SIGNAL, ABS, CHECK ENGINE, AND MPH OR KM/H UNIT DESIGNATION; TANK MOUNTED ELECTRONIC FUEL GAUGE WITH LOW FUEL LED INDICATOR
COVERAGE
COVERAGE 5 YEARS [OF COVERAGE]: 1 YEAR LIMITED WARRANTY + 5 YEAR EXTENDED SERVICE CONTRACT SUBJECT TO $50 DEDUCTIBLE WITH NO MILEAGE LIMITATIONS.
STANDARD - YET SPECIAL FEATURES
1 / 6
THUNDER STROKE™ 111
The new Thunder Stroke™ 111 engine delivers an incredible 119 ft-lbs of torque and features styling that pays tribute to legendary Indian Motorcycle® engines of the past.
KEYLESS
Enjoy keyless starting that’s secure and convenient. With the Indian® Chief® Vintage key fob in your pocket, climb on the bike, push a button and ride. If you misplace the fob, use the individual security code that you pre-programmed into the ignition.
EXTENSIVE CHROME
Virtually every surface that could be chromed has been chromed. From end to end, the beautiful, bright chrome finish elevates the iconic style of the Indian® Chief® Vintage.
GENUINE LEATHER
The comfortable seat and spacious saddlebags feature natural tan leather that will become even more distinguished over time. The high-quality leather is strong and durable, and it complements the traditional Indian Motorcycle® style.
QUICK RELEASE WINDSHIELD
The protective windshield features Indian® Chief® Quick Release Technology, so it can be installed or removed quickly and easily in just minutes.
5-YEAR COVERAGE/ROADSIDE ASSISTANCE
Indian Motorcycle® backs every new Indian® Chief® Vintage with 5 years of coverage that includes both a 1 year limited warranty and an extended service contract. Subject to $50 deductible, no mileage limitation. Ride with confidence and peace of mind that you’ll enjoy every memorable mile. Plus, every new rider will be provided a full year of Indian Motorcycle® Roadside Assistance for added assurance. See dealer for details.
Here are the specs. for the all new Indian.
SPECIFICATIONS
ENGINE
PERFORMANCE
DRIVECHAIN
1ST 9.403 : 1
2ND 6.411 : 1
3RD 4.763 : 1
4TH 3.796 : 1
5TH 3.243 : 1
6TH 2.789 : 1
FINAL DRIVE 2.2 : 1
CHASSIS
DIMENSIONS
LENGTH 103.7 IN
WIDTH (US) 40.4 IN
HEIGHT 58.7 IN
SEAT HEIGHT 26.0 IN
WHEELBASE 68.1 IN
RAKE 29°
TRAIL 6.1 IN
GVWR 1260 LBS
COLORS
STANDARD
ELECTRIC
COVERAGE
1 / 6
THUNDER STROKE™ 111
KEYLESS
EXTENSIVE CHROME
GENUINE LEATHER
