How to get tuneecu?
I'm on Windows. I don't know about Android, but it is a zipped file, and TuneECU uses .hex, so it would have to be unloaded or unzipped.
K&N in the airbox gives basically the same flow as stock.
So 20366, which is the tune running, is for what setup? Its not stock? Will that hex file work well with my setup? Ill chage pipes and intake eventually. But im having some poor running in the mid range and its a little twitchy going slow in 1st like all or nothing. Id like to change the tune and see if thats the problem.
Im going to use a laptop.
the description says Rocket III Touring Use with aftermarket silencers. (TORS) Replaces the 20258. That should be replacing the original tune number. It might be a little rich.
Thanks.ill double check the mufflers and see if they've been modified. It doesnt sound like a sewing machine but its no loud either.
