jcomp
2009 Triumph Rocket 3 roadster
Just got tuneecu loaded on phone. Got obd2 link. Having a slow start on 09 roadster. Runs good. Honda shop has it because they are my only option in wyoming. They've changed plugs which were shot. After changing we now have engine light on. I'm going to go in Monday to use tuneecu for first time to read codes and clear them. Looks straight forward. Is it accurate. Will remapping with tuneecu help problem? Is it accurate as far as where it leads you?
The new plugs didnt cause light, they probably left something undone, turned key on and boom light, no biggie, turn key on off several times light will probably reset, if not tune ecu will reset, if it recurs youll know whats up. Check isvc reset to verify numbers on tps and stepper. If you mess with tune read and save it first. Tune ecu is great.
My obd lx will allow to reset a code , i always use cable, ive had this vag/kcl. The obd lx i did not like and dont use.
