Be careful because if it has a the blower on it the miss your felling could actually be a detonation which can be hazardous to the engine. A note about broken crankshafts which I have always worried about and have been following them to hopefully learn something and thus keep from having one myself. Richard is right about drilling the crank off center or kattywhompus, this can definitely add to the chances of breaking the bolt or the nose of the crankshaft. Other reasons in my opinion that can cause this includes not drilling it deep enough and thus when applying the proper torque to the bolt you can actually attempt to pull the nose of the crank off the shaft, ( one must take into consideration the nose length of the tap dril and the amount of tapered threads a tap has on it to insure he drills it deep enough for complete threads) other things like detonation can be unhealthy to the nose and like Les found out the rod journal. On other thing people need to realize is a combination of things can happen like slight detonation or heavy engine breaking can make the OEM tensioner release losing timing. When this happens Mr valve meats Mrs. Piston causing a abrupt stopping or hammering affect of the crank shaft and well the planetary power of the blower drive which is almost a 10:1 ratio which makes it want to keep spinning. This of course is not good for the weak link of the crank which is the nose. all heck then brake loose and well its just costly. A Rocket owner I know had a blower bike that had a repaired crankshaft done by Richard which had such a good job of repair that the nose of the crankshaft did not fail. His tensioner did ( because it did not have a manual one or the Warp Aerospace modified OEM model) and it jumped timing. This resulted in the need of a new head, pistons, and liners because the valves broke off and nothing rotating fared out to well clearance wise when the piston came up and the valves were standing on the edge.
Remember this is just my own opinions and I have only been a tool maker since 1976, so like I say I have a couple years experience in the metal trades
