Welcome from Germany! Only a short ride away from you in the Rhineland Pfalz! Do you have any indication of the oil "leaking" somewhere?
Guntentag Cardinal93, danke schön, no indication of the oil "leaking" somewhere, the engine is really clean.
I will not try to translate my mechanical advice to him in "franglais" as I would not understand it either but lets be fair here OK french canadians are a great bunch matter of fact I am talking to an R3 french canadian owner who want to sell his 2013 rocket3 roadster with 8000 miles for $11000 which I believe is a bargain I am yet undecided I need a push from this forum to travel 2000 miles to buy it
Which part of Quebec is he in?
I would say do an oil change then. Drain the sumps, and refill with the 5 Liters. Then check your oil hot and cold levels. I think you'll find everything is perfect! We'll have to hook up in the spring time for a ride! My beastie is already in storage and the engine pulled for some work this winter.
I always drain oil measure it and add the same back in start engine, run for a few minutes stop engine, wait 5 minutes and then check oil adjust as needed.
