Nungers
.060 Over
Geraldton WA
2011 R3R
I need to replace my headlights, both have suffered damage over the years.
What options are there out there aftermarket without buying genuine
If I replace with LED, are they pluyg and play
Cheers
These are for standard/classic/roadster dual headlight rockets not touring
These are plug and play for main lights if you want the day time running lights which is the tiny little bulbs when you turn your key to aux you will have to splice that or just do what I did and don’t you don’t need them you’ll still have low/high beams
Got any pictures of them installed on your bike? How much brighter are they over stock?
Cheers
I went with Hog Lights. Straight swap and plug and play
Practically any 5.75" LED units will fit in the shells and the difference is incredible. You can even get lights with built-in indicators and DRLs which really modernise the look.
Go for it - you won't regret it :thumbsup:
I test headlights. The OEM Rocket headlights are criminal they suck so bad!
Nothing is as good as the JW Speaker Adaptive 2s.
I just purchased a set of Eagle Lights, black/no halo ring, and the installation is NOT going to plan. The flange on the Eagle is 1/8” thicker than the OEM and the beauty ring does NOT want to fit around the light deep enough rearward to allow the factory screw to catch its threads. The beauty ring won’t tighten enough. The Eagle flange measures that 1/8” thicker and since the beauty ring is smaller (inside diameter) at the front than the rear, I’m stumped if I can figure out how it’s going to fit. Any experience with these?
There is an OEM option, the ones from the Rocket 3. They're branded Triumph but actually made by JW Speaker.
Pity they didn't make them adaptive while they were at it.
But they do look the prettiest of all the LED options out there imo.
