Doesn't say anything about the running light rating unfortunately, only the main headlight LED power at 30/45 W which is irrelevant to Fuse 10.
You were correct Sir fuse number 10 was the culprit, I made sure everything worked in stock configuration and it did. I then reinstalled the LED headlamps and everything worked properly, I did buy a 5 pack of the 5 amp fuses and put them in my pack in case it does it again. If it does what would be next to try, load imbalance resistor or something similar.
doctor diode comes thru again,ANYthing elec. he is the man to go to
The OEM lights SUCK . . . BIG TIME!!!
They are NOT safe for night riding at highway speeds!
Go LED.
I finally installed and tested the headlight nacelles you gave me Steve. WOW! What an improvement. I drilled the reflector and installed the little German lights so I still have a little amber glow.
This works for me:
Harley Davidson Daymakers and a 6" LED light bar, works for me
Do the Daymakers go in without any modifications?
Tony,
Was surfing around trying to find a similar small light bar like yours.
Could/would you provide a name or link?
Merry Christmas to you and your lovely girls!
