Hagon rear shocks
I would be interested in both. I went Progressive for much the same reason you went Wilbur's... the Ohlin's catalogue is atrocious at best. I just didn't want to spend more than necessary until I figured out what Ohlins would work.
*edit* And thanks for doing the legwork on yet another aftermarket accessory
Hoping this sorts out my high speed wiggle I get when shifting 2-3 and 3-4 when I don't use the quickshifter. Bikes butter smooth with the QS, but hoping this fixes the little shake it does sometimes. Almost like when you watch the Isle of Man races and you see their bikes wiggle on power up shifts, mine does that, it's uh... disturbing. He's confident proper valving up front will sort it, his theory is the massive weight transfer of a heavy bike with a lot of torque is just overwhelming the crap stock damping in the forks.
If this fixes it, I'll probably not install a damper after all, prefer to not add things to a bike I'm trying keep on a diet.
The front end will require you mail in your forks, but it’ll come back setup for your riding style and weight.
Make sure you mention Ground to axle centre heights - Esp if you are about to move from Metz/Avon to an E-Max. And if you are dropping front tyre size. I noted substantially more tendency to nose dive after fitting the E-Max.
AirGap! - It matters. It makes a big difference to effective spring rates.
If they're any good at their job - this they'll know. But the R3 challenges suspension designers - It's the weight xsfer and unsprung rear weight.
I wish I had compression damping adjustment though. Front and rear.
From our discussion, he seems to know his stuff about as well as one possibly can. Said he'll need to keep the bike a few days to get leverage angles, stroke lengths, weight, etc etc so he can set it up right. The only thing I'm kind of concerned with, is that my bike is not a good representation of a "stock rocket" to develop from so I'll be sure to convey the things I've done that change geometry to him.
I'm super excited to help develop another suspension option, one that'll be specific to the R3R and better than the more commonly available items.
Of course no one claimed otherwise. Multi adjustable suspension that has pedigree and is properly developed INTERNALLY will apples for apples deliver excellent adjustability response for widely varying scenarios.
But consumers need to be careful what they wish for, you can purchase low cost shocks with adjusters that seemingly have a ''wonderful'' external response range. Those of us in the suspension industry of course know that this is largely a sham, if the piston and valving design / calibration is crude and aggressive of course you are going to get a wider response range on the adjusters because the seat pressure on the shims is high. So in a sense its little better than adjustable ''fixed orifice'' damping, i.e too much of the damping is on the adjustable bleed bypass instead of properly modulating and suitably responsive shim stacks. Conversely, with very soft main valving stacks that open earlier and wider your external response range to adjustment becomes a lot narrower. This can be graphically seen on a shock dyno. We rely on dyno AND seat of the pants testing. Note that a dyno assists in getting the force curves where they need to be but what a dyno doesnt show is transition. You can have two force curves that look exactly the same on the dyno and will overlay the same, with different valving. One will be a clear winner on road.
There are many non pedigree damper manufacturers that proudly boast ( for example ) ''40 clicks of compression adjustment''.........so what, only about 5 of those clicks are truly useful
One set of Rocket 3 Wilbers that we recently came in contact with were quite terrible, I rode the bike and adjusted it every which way but achieved no credible level of ride compliance. Clearly they were oversprung ( and overdamped ). I tested the springs and they were the same as the oem shocks in rate. But the point is if you have effective low speed compression damping ( which the stock shocks dont ) you can actually come down in spring rate quite significantly, in combination. We have been through all of this with many custom build twin shocks
The purchaser of these Wilbers purchased them offshore in a less than well considered impulsion on the keyboard, believing all the hype. He was quite distressed how badly they worked which is why he came to see me. Likely these shocks would have worked ''okay'' on relatively smooth autobahns or American freeways with a ''well fed'' rider and extra loading on board. But OUR roads in NZ are anything but smooth and very much challenge suspension, the purchaser was also ''not so well fed''. Short of dyno test it was VERY clear that the shocks were oversprung but also overdamped.
I have no doubt that Wilbers inherently make some good stuff but here was a harsh reality how offshore purchases of product that has no local distributor or proper backup infrastructure can lead to stressful issues. The springs on these shocks were quite different in size and I prompted the purchaser to go back to the seller and in the first instance request softer rate springs. He was met with a ''stone wall''....''all of the Wilbers shocks we sell for Rocket 3s have that spring rate, no one else is complaining''. Of course the seller, secure in his office many thousands of kilometres way has happily clipped the ticket and has no idea of our roading conditions. I would also lay money on it that the Christchurch purchaser of Wilbers has settings that could also be appreciably better.Even though he may not realise it. Indeed they will be better than oem and cheap shocks, but improvement is always a term of relativity.
Sadly, this sort of nonsense goes on all the time, and if you purchase suspension that is an ''orphan'' in the market you are inviting such issues
As for the cheaper brands I stand by what I said, they are abysmal and you only get what you pay for. There is no good reason to be ''nice'' about poorly engineered and poorly performing products that contaminate world markets. Indeed, the same for oem suspension. Yes, properly engineered suspension does cost a lot, but its inexcusable when properly engineered suspension is delivered with settings that are not right. And no intent to put it right.
Older readers particularly in the US will remember Ralph Nader, an automotive industry watchdog in the 60s and 70s. He exposed a lot of dodgy stuff and certainly a modern day reincarnation is sorely needed
Well said KSS! 100% agree.
It’s a fact the Wilber’s are sprung stiffly, no doubt.
Well said KSS...now how much to make me some?...delivered to Chch. ..I'm 110 kg with my gear....pillion hardly ever...and how long to make them...serious..
Send me an e-mail please to sales@kss.net.nz
