What does a R3 gearbox sound like(tried the search function)?
Mine makes some whirring and very faint whining noises depending on rpm and the load,its done 13000klms
I cant detect any abnormal sloppiness in the drivetrain.
Im just want to ascertain whether they should be dead quiet or is a little noise as described above normal?
Mine whirls and whines when running in gear; changing in tone and disappearing as the rpm's pick up. And clunks/clinks/clanks slightly when shifting gears.
You've much described it. I was (and still am) a big fan of the cartoon, "The Jetson's", and I always thought the Rocket tranny noise at idle was very similar to the sound of their aerocars. I'm told the noise comes from Triumph's use of straight-cut gears, which are the strongest design, though noisy. It just adds to their uniqueness.
Earplugs work, too. To be honest, the first long trip I took I wore earplugs for the wind, mostly. Anyway, after my first fuel stop I forgot to put them back in. Sitting at the intersections and making the slow migration back to the interstate I became real concerned about all that noise...it didn't seem to be that noisy before. Then I realized, "Yeah, it wasn't that noisy before because I was wearing earplugs. Anyway, it was funny to me. I guess you just had to be there. 8) Bottom line...they make their own sound...you go your own way. 8)
Ill be getting ear plugs.
I just did a 350 klm ride and I can still hear the noise from the Jardines 10 minutes after I shut it down :?
A couple of the other guys had choppers with S&S engines and the noise they made was atrocious and in the distance I kept thinking there was something banging inside my engine :shock:
