warp9.9
Pocałuj mnie w dupę
exactly what my thoughts were.I believe yours will have the "sealed" bearing at the rear of the torsional damper. That was an upgrade on the later models. That is likely a bit of the grease that has escaped the seal. Probably a normal occurrence due to repetitive hot / cold cycles of the engine.
Also just in case the front bearing with a single seal sbould have to open side facing forward. Its been a while since I have seen one in backwards but it has happened. Should look like below
