Correct, there is no advantage with running higher octane than specified in the owner's manual. The difference between lower and higher octanes are additives that prevent pre-detonation and slow burn process within the cylinder to prevent detonation (with no additional performance gains). If your engine makes say 150HP using regular, it will still only make 150HP on premium fuel or visa-versa. If however your high compression turbo bike pings on regular, not good, need higher octane. Now added detergents are a different story. Most major auto manufacturers have identified the top tier fuels to use. The top of the top tiers are Shell, Exon/Mobil, Amoco. Exon/Mobile has the highest detergent concentration in regular blend, followed by Shell then Amoco. Shell has the highest detergent blend in premium, followed by Exon/Mobil, then Amoco. If you avoid the no-name gas stations and use good quality top tier fuels, you should not need additional cleaners to keep your valves clean.
