Thanks,
Its been unchanged for some time now, if I ever get the time I have some new ideas, gettin the itch .........
Lonnie
I'm actually putting some small chrome bits back onto my bike .. chrome is the new black :thumbsup: after looking at all those all black Roadsters .. time to change a few things like you said.
I used a M109R front fender, gets rid of all the trim as well as the chrome fork protectors all in one!
You do have to make an adapter plate for the front two bolts on each side, but well worth it IMHO.
Hope this helps.
Lonnie
I REALLY like that cool rear fender rack!!!!
That looks awesome. Where's the pointy bit under the radiator from?
The Chin spoiler is from "Evil Bob" He's in the UK, a member here or the .com site, can't remember its been so long ago.
In good time my friend, Did you get my reply to your conversation??? If not send me the measurments.
Lonnie
Hi, this is Georg from Germany. I like your modified Suzuki fender very much. Before purchasing a Suzuki fender I would like to know how this adapter plate looks like. Is it difficult to produce it? A pic would help.
Thanks in advance for your kind reply.
Georg
Georg
Georg,
I don't have any pictures as the plate is hidden behind the fork guard part of the Suzuki fender. It has been some time since I made the adapter plates, but I do recall that I made them from 1/2" thick black plastic plate, (called Nylatron here). I simply countersunk the bolts in the original locations on the plate so the heads are below the outside edge of the adapter plates. I then drilled and tapped the plate with holes that aligned with the Suzuki bolt pattern. I do remember that the bolt holes are very close to the Triumph holes on the two bolts on the front. The single rear bolt on the rear on each side requires you to trim about 1/2" off of the boss on the fork lower, no other modification is required for the rear bolt.
Hope this helps, if I get a chance I'll try to get a pic, but the bike is pretty packed in for winter right now.
Lonnie
Georg,
Lonnie
Lonnie,
thanks a lot. I think your description will help. Will right now look for a plastic plate that fits :)
Have a good time.
Georg
Lonnie,
I got a Suzuki front fender and tried to adapt it to my Rocket. It worked fine as described by you but I noticed, that the clearance between the fender and the front tire is just a few mm, maybe 2 or 3 mm. This seems to be too little as the tire will expand at high speed and will probable touch the fender. Maybe this is of no importance at typical low speed as in the US, but at top speed on the german autobahn this effect could become dangerous.
On your bikes pics the clearance seems to be better. Maybe due to the fact that you ride Bridgestone tires with less radius instead of Metzeler?
Regards, Georg
Write your reply...
