Free unrestricted maps for Rocket R GT and TFC now online
Hello I am new here and have the Rocket 3r 2021 (mybe 2020 ) for 1 mounth now . My vin number end with AV4287
is there a proper file for me ?
Thanks
Thanks
Go look on the TuneECU custom tunes page at Custom Tunes, you also need to get the one for your region, not just the VIN range. All the 2.5 Rocket sections are at the bottom of the page, yours will be the US/Canada or ROW tune in the second section. To confirm, you can also plug into your ECU and TuneECU will tell you the map version (31018, 31019 etc) to make sure you're getting the right one.
Thank you. I am not from USA or Canada ( from Israel ) I am not sure what region the bike from . I will get my ODBlink LX in few days and will check
thanks !
I have now added the TFC and R model
Just scroll to the bottom of the page
The European models will come soon
Cheers
Hi, I'm a newbie so please forgive me. I need help, I have a Triumph Rocket 3 TFC 69 plate. I'm trying to remap my bike using a OBD link MX+ & TuneECU. I get as far as ETV3 on my tablet, I press the bottom far right figure 100 nothing happens, I try again press the 100 figure then table at the top, modify is not highlighted so I can't press it!! Any idea where I'm going wrong?
Have you used TuneEcu before to remap?
You’re trying to edit a map, right? What do you want to accomplish?
Yes, I'm trying to edit a map, ETV3, last two columns 100 then 70 then 60 then 50 then 41 then 33 going right to left. It's just when I have the map page on the tablet, it won't allow me to modify!!!
So you open the table tab, then modify. It first gives you a warning, hit continue. Then you see a red X and a grey check upper right. If there is a 100 in the lower right, push on it with finger tip until it turns tan. On my tablet it frequently doesn’t work but it will. Then upper right you see two offset blue pages. This is copy/paste. Press on it, then hit copy. Now press the top cell in the 100 column and hold it as it turns tan. Then drag it to the bottom until the entire column is tan. Now hit the blue pages on top and hit paste. Hit the green check upper right to save your edits. Now save the map and do the same for the 91.2 column. There are Penner’s maps which you can use to derestrict also.
Thank you for taking the time to read my message & reply. I found your message very useful, thank you. All done now, about to take it out for a spin.
Write your reply...
