imcool
Turbocharged
- Joined
- Feb 22, 2022
- Messages
- 786
- Ride
- Rocket 3R 2022
I read somewhere that you need to unlock the speed limiter on the stock tune before downloading the Penner tune and there is an associated fee. No issues with paying the fee but not sure how to go about that and how to proceed.I have a 22 R3 R. I added the quickshifter and heated grips. I am on IOS and didn’t have an Android device so I bought a Samsung tablet as well as an OBDLINK MX+ adapter. I am in the US. It looks like my stock map would be 31019 based on my VIN. I looked for Penner’s tune and it appears I need “Rocket R USA Full Power 31019Map.hex” to uncork it. I am ready to load the tune but have a few questions before I proceed.
Do I need to upload the stock map from my ECU into TuneECU and unclick some tick box there whereupon it will reach out to Alain’s server to complete the transaction? Or do I need to download the stock map and do something with it, such as tick a box to remove the limiter and thereby initiate the payment transaction?
Or can I just do this all to the Penner map during the loading process to unlock the speed limiter?
After all this and I’m ready to load the Penner tune, will there be any impact to the quickshifter or heated grips once I load it? For example will this tune overwrite the settings where I’ll have to go back to the dealer to have them enable again?
What is the current consensus on resetting the adaptations? I’ve read so many conflicting opinions that I am not sure which way to go on this.
I plan to add a slip-on exhaust. In general, has anyone found the need to re-tune the Penner tune after a simple muffler swap with something like the Competition Werkes? I’m going with Verex, but they all seem restricted by the header, like my earlier Rocket III.
Is there a good YT vid that covers what I might have missed? I looked at a few, and they tend to skip around and miss key points.
Are there any key things I am missing or other tips to be aware of? I understand the need to pull the headlight fuse and put it on a battery charger. I don’t want a voltage drop and be forced to recover.
Thanks in advance for any insight/advice.
I have PRO version of Tuneecu so I cant tell you but as far as I know when you have normal tuneecu version then you have to email tuneecu developer and ask them to send you an unlocked map
if you get pro version, then there is just a tick box but if you dont have pro version then you have to email and pay and wait for them to send you unlocked map (AFAIK),
no you cant do anything while the map is loading and do not do any thing while the map is loading, just look at it.
no issues with heated grips or quickshift, I am using it for last 2 years, no need to see dealer after flashing map.
do not click that button 'reset adaptations' even by mistake while loading map, lots of people who dont pay attention run that and end up with that issue, not a big deal to fix but its headache, not recommended to run that 'reset adaptations' at all.
I am running werkes with penner map and there are dyno runs + valve+sparkplugs pictures of my bike after 1+year , no issues no need to retune unless you changing headers
on youtube there is one for triumph street triple loading map with tuneecu, different bike same procedure
Make sure battery charger is connected
Headlight fuse is removed
tablet is charged
you are mentally sound ( dont fight with girlfriend/wife. long day after work argument with boss/yelling workers etc. prior to flashing tune for first time)
once you do it, its very easy for next time.
double check, triple check your VIN against the tuneecu map you are flashing.
if you are in doubt go to tuneecu forums and ask there which one is correct map OR someone here with same vin range can confirm that.
