Jay
E pluribus unum
- Joined
- Jan 3, 2019
- Messages
- 873
- Location
- California, USA
- Ride
- 2023 Rocket 3 GT (Ego), 2021 Zero SR/S (Earth)
Here is where I am at. I used a 5/16 cap screw to mount the left mirror on the clutch perch. I made two spacers that fill the hole and step it down to 5/16. The flat top of the clutch perch is fine for the mirror. My real issue is the brake side with its rounded edge that leaves marks on the bottom of the mirror. See the picture below to see how the mirror sits on the brake. What I want is to raise it up a bit to clear the rounded edge. So I have a nylon spacer to hold it up and a 5/16 bolt long enough to go from the bottom to the mirror with enough threads in the mirror for strength in the aluminum arm. Note though that the mirror mounting hole has a shoulder in it, so I had to cut a couple sections of pipe to made spacers to fill the space. Essentially my stack of spacers follows the profile of the mirror mount or those Kuryakyn mirror adaptors that @warp9.9 linked to.
