Final drive - bevel box breather removal
if u should get it apart and fix it i think that u should torque those 6 bolts to about 50nm torque.
now i have been shut down for this idea i am about to type
there may be or may not be a hole in the front of the final drive just above the inside lower stud that may let motor oil drain from that tube.
a good pic of that area would prove me right or wrong.
Okay, I will check for the motor oil drain hole.
But I have drained and re filled.
Measured what came out, pretty close to 170ml, but not more.
Have refilled and we will see.
I have to say that I think it had pretty much stopped leaking, what was still coming out was probably what was inside the hub.
Have given it a good clean too, but used the air compressor to blow into the breather.
Fingers crossed,
There is nothing like good clean oil to prolong the life of these units. The engine needs it too and I change all the oils together regardless of mileage just to help longer service life.
Also I don't trust the dealers to carry out the full schedule of work either.
