Super D.
@Super D. I have 2 Rockets...an '09 standard running a Reband system and a '13 Roadster running a CES system. Both bikes have been dyno tuned. Both bikes run hot on the leg. Sitting on my bike lift absolutely cold at ambient temperature then fire up and let it idle for a minute or so and my little laser temp gun puts the header temp right at the block in the 500 F range...not revving...just idling for a minute. So the answer to your question is YES...aftermarket pipes are hot, and YES I will eventually get tired of it and fab a heat shield. Both sets of pipes have been coated by the original manufacturer and two different shops since in an attempt to reduce the heat. My problem is that I like black, and black ceramic coating does very little to reduce heat. If you like the silver look you can have them put a ceramic coating on your headers that contains aluminum oxide which I'm told will provide significant heat reduction. Haven't tried that yet as I'm not a fan of shiny stuff so much. Hope this helps
Than you sir.BTW...I would expect that the header temp gets well above 700 degrees when the rpms come up. As a frame of reference the tip of a cigarette burns at about 750 degrees F when not being drawn on. Anybody want to volunteer to get a cigarette put out on your leg every time you go ride?
Thought not...
Edit: Having said all of this I still want one of Paul's systems to replace my Rebands. Them things are moto **** in my opinion. Sexy work there @Paul Bryant
