Engine Management Malfuction light
What smore important, My Rocket or your bathroom? lol:D
If its been sitting for a while check for simple things as it is a 06 how many times have you cleaned th elow tension leads and re-crimped the leads to the coils? I would give that a try plus clean battery cables and re attach corrosion is a leading cause of burps in the system. It is easy to sheck and maintain except the fron coil is a little hard to get at but worh it. as you will also be able to diconnect other cable conectpors going to the front coil. they could be corroded. also. if you need some pictures on the low tensinon leads of th ecoils I will post some to make it easier. Buy soem dialetric grease so you can prevent corrosion later. And while your at it make sure battery is at full charge. especially if you never have changed the battery yet.
Took the Rocket to dealership! They checked the TPS and it checked out good! Found it was the Throttle Stepper Motor! Running good now! Thanks for the help guys. I have a laptop and think I'll order a OBD2 cable and see if I can start locating problems on my own! :eek:
