Did you try letting it run the 12 min tune ?[/QUOTE
No, I didn't! It was running pretty rough and not sure it would stay idled that long. I turned it off as soon as the warning light came on. Should I try to run the 12 min tune?
No I wouldnt.
Check everything that you can. Oil level, air filter, etc.
You may even disconnect the battery for a few min's then try again. If you do that and the light comes on again I would shut it off immediately.
Hopefully someone with more experience will be on soon.
