We've now done the Barometric Pressure Sensor with no change, good suggestion and worth a go.
Also did the AT Sensor and have decided our rich mixture is a false lead as once we swapped the sensor (was cooler and not in a filter) the bike AFR was exactly the same as my bike as a comparison at the same air temps so think this is just due to us sitting there idling too long and getting the AT sensor too hot, odd but Ithought it would have leaned out as the temp increased?
Have increased the idle (but still cant get 1100, 100rpm being our target so we know quickly if changes have worked) by the following.
1. Manually adjusting 7mm idle stepper nut till motor runs at setting in Tune ECU at set temp (1100rpm above 75C).
2. Performed Reset Adaption.
3. Performed TPS and ISM reset
4. This Got bike to increase revs slightly.
Repeated above and it was better again but was now only up to around 800 to 850rpm.
Manually adjusted the 7mm ISM nut to again read 1100rpm.
I then changed the RPM target in the ECU to be 850rpm.
Restarted the bike and "Hey Presto" 650rpm again
We had then had enough for the day and manually adjusted the idle using the ISM nut to 850rpm and Paul went home.
Also took screenshots of Tune ECU page with Paul's and my Bike running to see the differences
Paul's Page The Throttle section here concerns me with the 99%
My Page (Bike runs Mint ignore 2ndry TPS fault cannot seem to get rid of).
Ignore below double up incompetance
