sunny
- Joined
- Jul 17, 2021
- Messages
- 397
- Ride
- Rocket 3R LIMITED EDITION
You had issues after flashing penner map?So I loaded the Penner tune yesterday with TuneECU, it loaded fine. I am not sure which version of the instructions I was reading, but it talked about resetting the adaptations, which I did, and now the bike is throwing a crank position code, P0315. It also threw a cruise control code, but the TuneECU instructions to reset that worked. I can't, however, clear or reset the P0315. I think it was because the bike took too long cranking after the reset, I instinctively stopped and restarted the cranking and twisted the throttle, which you shouldn't do. Tried resetting the adaptation again and doing the 15-minute idling procedure, no change. A thread on the TuneECU forum suggests only the dealer can fix it (Alain said that).
Further reading suggests it should‘ve been a load and just ride it process as the ECU adapts automagically. Annoyed at myself...
Any ideas? Bike actually rode ok, I took it for a ride (around 30km) thinking a run might clear it.
My friend flashed his rocket 3R in Australia with pro version and unlocked speed limit and no issues.
