.... I think mine (2010) had the light relay upgrade.
Touring do not have light relay - only the Roadster
The starter relay sends signal to the ecm, but that is all it does. ...
You have that wrong way round - the ECM is sending the signal to the Starter Relay - when that is 'low' and the starter command is 'high' the relay changes state and directs current to the Solenoid.
The main control to the ECU that enables that 'low' output to the Relay is the Clutch Switch (but there is also a low voltage threshold)
If you have no ignition power, the start switch will not have output.
Damm Kenny ! I started turning over rocks looking for you ! Where the hell you been bro ? You obviously aren't dead or in the can, so you better get that R3"T"urtle fixed and ride it to Maggie Valley in October ! Ain't no grass growin' in October ! Seriously, I hope everything is good with you. Most of us here have been behaving ourselves :rolleyes:
A Big +1 on that why the hell were you not at RAAX I WAS and hoping you would be so I could buy you a drink for your part in our Ring adventure
Great to hear from you Hanso. Would have loved to have met you. I will hold you to that drink when our paths meet
