EasTexRIII
I think my problem is resolved thanks again to this forum. I had replaced my driving light bulbs originally H3 35watt with H3 55watt. this has been causing some heat stress to the wiring. I am now looking at some led replacement bulbs to replace the 55 watts. Any suggestions?
I was going to suggest that. My 05 had that problem after changing the H-4's from stock bulbs to 100w "hi-vis" - 2 weeks later the frigging left plug melted - I spliced in some aftermarket high temp plug ends & that fixed it but a short while later I went ahead & changed out the units for LED's. But you certainly found your problem
